How Do I Enable a Data Field Downloaded From Connect IQ to My Edge?
After downloading and installing a data field from the Connect IQ™ Store, you will need to take extra steps to enable it for your Edge® cycling computer. You can add Connect IQ data fields to an existing data screen, or you can create a new data screen. Select an option below to reveal instructions.
NOTE: You can only use up to 10 Connect IQ Data Fields at one time.
Steps to Enable Connect IQ Data Fields for an Existing Data Screen
  1. On the Edge, enter the menu to access Activity Profiles.
  2. Select the activity profile you want to enable this data field on.
  3. Select Data Screens.
  4. Select the Screen you wish to edit.
    • Edge® 1050 only: select gear icon 1050 to change data screen .
  5. Depending on your model, select Layout and Data Fields or Edit Data Fields.
  6. Select add data field on 1040 or plus sign add field on 1050to configure the layout.
  7. Select forward arrow or check mark to confirm your selection for the layout.
  8. Double tap the data field you wish to edit. This will open the Select a Category list.
  9. Scroll down to Connect IQ at the bottom of the Select a Category list.
  10. Select the data field you wish to add.
  11. Select the checkmark to confirm your selection.
  12. Start your activity or repeat steps for other Activity Profiles.
Steps to Enable Connect IQ Data Fields for a New Data Screen
  2. Select the activity profile you want to enable this Data Field on.
  4. Select Add New.
  5. Select Data Screen.
  6. Select Connect IQ.
  7. Place a checkmark next to the data field you wish you add.
  8. Select the back arrow key.
  9. Select the checkmark to confirm your selection
  10. Use the arrows to reorder your new data screen. Select the checkmark when finished.
  11. Start your activity or repeat steps for other Activity Profiles.
Sujets connexes
