What is OpenStreetMap?
OpenStreetMap or OSM is a highly detailed map dataset that is used in many different Garmin products that feature mapping.  OSM is developed and added to by community mappers around the world. In many rural areas of the world, OSM has medium-to low-detailed data. Features are added and edited by community members with local knowledge. Coverage of features may vary and includes geographic locations, place names, landmarks, points of interest, hydrographic features, and land-use/land cover. OSM is an open data source. OSM also includes an open data source elevation dataset. The scale is not consistent because the OSM data is Volunteered Geographic Information. Scale detail can vary from 1:24K or better in major urban areas to much higher scales in more rural areas.
You can contribute to this database for future releases by adding, updating, editing and commenting:
  1. Go to OpenStreetMap.org.
  2. Create a free account.
  3. Follow the outlined steps for becoming a contributor.
    • If you prefer not to map the updates, you can add a comment at the location that needs reviewing and other contributors will review, investigate and apply the update when appropriate.
Termes et conditions OpenStreetMap ~ Certains produits Garmin comprennent des données OpenStreetMap. Les produits Garmin OpenStreetMap ne sont pas soumis aux termes de l'accord de licence de l'utilisateur final (ALUF), mais plutôt aux Termes et conditions ci-dessous. Les données OpenStreetMap sont soumises au copyright OpenStreetMap et les contributeurs sont soumis à la licence Open Database license. Tous droits concernant les contenus individuels des données OpenStreetMap sont licenciées sous Database Contents License
Pas de garantie ~ Les produits Garmin OpenStreetMap sont fournis « tels quels » , et vous acceptez de les utiliser à vos propres risques. Garmin et ses concédants de license, notamment les concédants de license, les fournisseurs de services, les distributeurs et partenaires de distribution, et les compagnies affiliées de Garmin et ses concédants de license, n'offrent aucune garantie ou représentation de quelque nature que ce soit, explicite ou implicite, découlant de la loi ou autrement, y compris et sans restriction, le contenu, la qualité, la précision, la complétude, l’efficacité, la fiabilité, la qualité marchande, l'adéquation à un usage particulier, l’utilité, l'utilisation ou les résultats à obtenir des produits Garmin OpenStreetMap, ou que le contenu ou le serveur fonctionnera sans interruption ou sans erreurs. Les produits Garmin OpenStreetMap sont conçus pour être utilisés seulement en tant qu'aide supplémentaire au voyage et ne doivent pas être utilisés pour tout usage nécessitant des mesures précises de direction, distance, localisation ou topographie. Garmin ne garantit pas la précision ou la complétude des données cartographiques des produits OpenStreetMap.
