Backing up user data from a GPSMAP 8xxx series device
Before updating device software, it is recommended that you backup user data like waypoints, routes, and tracks. This should be done in regular intervals to provide a good database in case the loss of user data unfortunately occurs. Backing up the data also provides the ability to edit the information and send it back to the device. The following items are required in order to back up user data:
- Garmin's Marine Trip Planning program Homeport
- A blank SD card (no larger than 32GB) and an SD card reader*
- A computer running Windows Vista or later
*The SD card and SD card reader can be purchased from most electronics stores.
To backup the user data, please follow these instructions:
- Insert the SD card into the SD Card Reader
- Power on the Chartplotter
- When the home screen appears, choose Info
- Select User Data
- Select Data Transfer
- Select Save to Card
At this point the user data will be backed up to the SD card. To view the information within HomePort, please follow these instructions:
- Connect the SD card reader to the computer
- Insert the SD card into the SD card reader
- Open the HomePort program
- On the left side of the program, the GPS device should be listed
- Below the device should be a folder called USER DATA. By default this is the name given to the file for the waypoints that were backed up. If this is not the first time the information has been backed up to this card, the device will ask for a file name. If a different file name was used to backup the data, that same name will show up as a folder under the GPS device in HomePort
- Select the folder that has your user data that lists waypoints, routes, and tracks
To backup the data to the computer, please follow these instructions:
- Right-click on the folder from the card that has your user data listed
- Choose Send To
- Choose My Collection
This will copy the user data from the SD card directly to the computer and automatically save it in the My Collection folder
