Viewing Live Video Using the Garmin Drive App
Live video footage can be viewed from your dash cam using the Garmin Drive™ app. The dash cam generates a Wi-Fi connection with the phone to display a live video feed so you can adjust the position of the camera. The standard distance the phone and dash cam can to remain connected is 30 feet. The Live View can be seen in either portrait or landscape orientation by rotating the phone.
To View the Live Video:
1. Pair your dash cam with your smartphone using the directions from the owner's manual of your device
2. Touch Live View in the selected Vehicle
  Drive App New - Live View
3. Touch Join or Connect
Join Wi-Fi Network1
4. Select the dash cam you would like to view if you have multiple paired.
    • Your dash cam will now connect to the app. This can take a few minutes.
Select a Camera Drive App
You will now be able to view the Live View on your phone. The Garmin Dash Cam Tandem will allow you to see the front or interior view.
NOTE: Recording and alerts are disabled on most Garmin Dash Cams while viewing live footage.
  • The following dash cams will continue to record:
    • Garmin Dash Cam™ X110
    • Garmin Dash Cam™ X210
    • Garmin Dash Cam™ X310
    • Garmin Dash Cam™ Live
    • Garmin Dash Cam™ 47
    • Garmin Dash Cam™ 57
    • Garmin Dash Cam™ 67W
    • Garmin Dash Cam™ Mini 2
    • Garmin Dash Cam™ Mini 3
    • Garmin Dash Cam™ Tandem
  • The following devices will not continue to record:
    • Garmin Dash Cam™ 46
    • Garmin Dash Cam™ 56
    • Garmin Dash Cam™ 66W
    • Garmin Speak™ Plus
    • RV 785
The following devices can use the Live View feature remotely (when the dash cam is connected to an active Wi-Fi connection):
NOTE: A Vault subscription is required for Remote Live View on the Garmin Dash Cam™ x110, Garmin Dash Cam™ x210, Garmin Dash Cam™ x310, and Garmin Dash Cam™ Mini 3
Garmin Dash Cam X110, X210, X310, Garmin Dash Cam 47/57/67W, Garmin Dash Cam Mini 2, and Dash Cam Mini 3, see Using the Live View Feature Remotely on a Garmin Dash Cam.
Garmin Dash Cam Live, see Remote Live View with Wi-Fi or LTE on a Garmin Dash Cam Live .
NOTE: If the Live View does not load or appears to be stuck on loading, try toggling the Wi-Fi setting on your phone and the troubleshooting linked here, Unable to View Videos or Live View through Wi-Fi in the Garmin Drive App.
