Changing the Home location on a nuvi 300 series device
Your Garmin automotive device has the ability to route directly to your home by using the Go Home feature. In some cases, you may need to change the home location.
To change the Home location:
- Touch Where to?
- Touch My Locations
- Touch the Set Home button at the bottom of the screen
- Select the desired option for setting the new home location
The home location has now been changed. Repeat these steps as needed.
