L'article présenté sur cette page n'est pas disponible dans la langue que vous avez sélectionnée. Vous pouvez en choisir une autre ci-dessous.
Tacx Serial Number Format and Location
Serial number information is located on a sticker affixed to each Tacx® smart trainer. The location will vary according to each model. To view the location, select your trainer below. For information about registering your Tacx smart trainer, refer to: How Do I Register a Tacx Trainer?
NOTE: To find the serial number for your Tacx smart trainer in the Tacx Training™ app, refer to: Using the Support Tool in the Tacx Training App
Tacx NEO Bike Series
  • Tacx® NEO Bike smart trainer
  • Tacx® NEO Bike Plus smart trainer
Located on the non-drive side next to the left crank arm
Left side of NEO bike with sticker circled
Tacx NEO Series
  • Tacx® NEO smart trainer
  • Tacx® NEO 2 smart trainer
  • Tacx® NEO 2T smart trainer
Located on the underside of the non-drive side leg
Bottom side of a NEO smart trainer
  • Tacx® NEO 3M smart trainer
Located under the drive-side leg
3m serial location under driveside leg
Tacx Flux Series
  • Tacx® Flux smart trainer
  • Tacx® Flux S smart trainer
  • Tacx® Flux 2 smart trainer
Located on the back side of the rear, drive side leg, next to power port
Rear of a Flux trainer
Tacx Flow
The serial number for the Tacx® Flow smart trainer is located on the resistance unit.
Back of a Tacx Flow trainer
Tacx Vortex
The serial number for the Tacx® Vortex smart trainer is located on the resistance unit.
Bottom of a Vortex trainer
Tacx Boost
The serial number for the Tacx® Boost trainer is located on a small white sticker located on the base of the frame
serial number sticker on boost trainer
Tacx Roller Trainers
  • Tacx® Antares roller trainer
  • Tacx® Galaxia roller trainer
Small white sticker located on the side of the left leg
serial number on the frame of rollers
