L'article présenté sur cette page n'est pas disponible dans la langue que vous avez sélectionnée. Vous pouvez en choisir une autre ci-dessous.
Garmin Aviation Database Manager Not Opening on Windows
Follow the Steps below if the Garmin Aviation Database Manager is not Opening on a Windows Computer.
  1. Close the Garmin Aviation Database Manager by following the steps in  Where can I Close out of the Garmin Aviation Database Manager using the System Access Tray on a Windows Computer?
  2. Repair the Garmin Aviation Database Manager application.
    1. Press the Windows Button and "i" on your keyboard to open the settings menu.
    2. Select Apps in the settings menu.
    3. Locate and Select the Garmin Aviation Database Manager.
    4. Select Repair and follow the prompts in the Setup Wizard.
    5. Launch the Garmin Aviation Database Manager.
    6. If the issue persists, proceed with the steps to Uninstall and Reinstall the Garmin Aviation Database Manager.
How do I Uninstall and Reinstall the Garmin Aviation Database Manager?
  1. Uninstall the current version
    1. Go to your computer's control panel.
    2. Select Programs or Programs and Features or Search Add or Remove programs.
    3. Find Garmin Aviation Database Manager in the list and select Uninstall.
    4.
  2. Restart the computer.
  3. Download the latest version of the Garmin Aviation Database Manager.
  4. Open the downloaded installer file.
  5. Follow the on-screen instructions to complete the installation.
  6. Restart the computer after reinstalling.
  7. Launch Garmin Aviation Database Manager.
