Incorrect Battery Reading
When using the Delta InBounds system with batteries, it may be possible to see an incorrect battery reading. If the battery level is incorrect, ensure that only Alkaline batteries are used. The device is designed to function with Alkaline batteries only. Other battery types such as lithium or NiMH batteries will result in incorrect readings.
