How to Configure SRAM AXS Shifting on Edge Cycling Computers
SRAM AXS electronic shifters have buttons on the top of the hoods that can be configured to control certain functions on compatible Edge® cycling computers. To pair the shifting system to your Edge cycling computer, refer to your owner's manual.
Compatible Cycling Computers:
  • Edge® 540 | Edge® 540 Solar
  • Edge® 840 | Edge® 840 Solar
  • Edge® 1040 | Edge® 1040 Solar
  • Edge® 1050
How Do I Configure the SRAM Buttons?
First, assign ANT+ Functions in The SRAM AXS App:
  1. Install the SRAM AXS App on your compatible smartphone.
  2. Add your AXS components to the SRAM AXS App.
  3. Select Configure Controls.
  4. Select a component.
  5. Select ANT+ Control
  6. Assign an ANT + Function of your choice to the component.
SRAM App Screenshots  for configuring ANT function While the SRAM AXS system is paired and connected to the Edge:
  1. Access the Edge's list of Sensors.
  2. Select the SRAM AXS Shifting system.
  3. Select Sensor Details
  4. Select ANT+ Function Setup
  5. Select Action Type.
sram edge screenshots in sensor details
I Am Seeing AXS MicroAdjust Appear On My Edge
When you make a change to the MicroAdjust in the SRAM AXS App or using the AXS buttons while paired to a compatible Edge, the Edge will show a screen similar to the one below. The middle number will update as you make adjustments.
microadjust
