What is Peloton Mode on the Varia RTL515, and RCT715?
Compatible Varia radars taillights have a Peloton light mode. In Peloton mode, the taillight switches to a lower light intensity to be easier on the eyes of riders behind you in a peloton (group ride). If a vehicle or rider approaches quickly from behind, the radar will pick it up and the light flashes softly.
Enable Peloton Mode With a Connected Edge Cycling Computer
Step 1: Ensure Device Compatibility
Compatible Varia devices
Varia™ RCT715
Varia™ RTL515
Compatible Edge cycling computers
Edge® 530
Edge® 540 | Edge® 540 Solar
Edge® 830
Edge® 840 | Edge® 840 Solar
Edge® 1030
Edge® 1030 Plus
Edge® 1040 | Edge® 1040 Solar
Edge® 1050
Edge® Explore
Edge® Explore 2
Step 2: Enable Peloton Mode From the Connected Edge
Peloton mode is enabled from touchscreen Edge devices differently than on button controlled Edge devices. Touchscreen Edge devices allow easy access to a widget menu during a ride where you can adjust the light mode. Button controlled Edge devices require an extra step to access this light control. A Light Network must be formed between your Edge and Varia before you begin this step. For instructions on forming a Light Network see: null or Control Your Varia RCT715 With an Edge Cycling Computer depending on which Varia radar you have.
Touchscreen Edges
Newer touchscreen Edge devices have a dedicated Light Mode widget that is available when a light network is formed. This allows you to easily change the Light Mode to Peloton during a ride.
To access the widget:
Swipe down from the top of the screen to access the Widget Menu.
Scroll to the left or right until you reach the Light Mode widget.
Select Peloton.
This change only affects the current ride in which you make this adjustment. To keep your Varia in Peloton mode permanently for all of your rides follow these steps:
Select > Sensors > Lights.
Select Network Options and ensure Light Mode is set to Individual.
Go back one screen and select Radar.
Select Light Mode and change it to Peloton.
Button Controlled Edges
On the Edge 530 and Edge 520 Plus, Peloton mode should be set up before starting your ride. After making this change, the Varia device will default to Peloton mode for the following rides.
Scroll down to Menu.
Select Settings > Sensors > Lights.
