Credit Card Failures inReach Subscriptions
You will be notified by INREACH the first time your credit card fails by an email message to your last email address known to INREACH. Your second notice with be sent 7 days later followed by a final notice 14 days after your first notice if the credit card continues to fail.  If INREACH does not hear from you that you have rectified the problem credit card then any devices associated with the credit card will be deactivated within 30 days from the first notice.
Cancellation* of a Service Plans due to a Credit Card failure will not relieve you of any otherwise applicable fees that may be due and will result in late payment fees and a reactivation fee.
*In regards to the inReach Service Plan, this is to put your device in a "deactivated" state where it will no longer function on the Iridium Network. Unlike with a Suspended device, devices that are cancelled most likely would incur additional fees for activation (Either and Activation Fee or Annual Plan Fee based on the plan chosen at activation) ###Warning: SOS services will not work for devices that are suspended. ###
Sujets connexes
