Using the Same USB Flash Drive for the Honda Map Update
When doing a Honda map update you may use the same USB flash drive that was used for a previous map update. Prior to using the flash drive for the new update however, you will want to completely format the drive. See Formatting a USB Drive for a Honda Navigation System for instructions on formatting.
Once the flash drive has been formatted, you will want to follow the full update process found at https://honda.garmin.com/honda/.
