I See a Course Point Max Exceeded Message on My Garmin Device
Course points include every turn in a course in addition to any manually created points added to a course that you have created and downloaded to your device. You may run into this issue if you manually add several points or if the course is extremely long in distance.
In addition, the message will include the number of points that your course has exceeded.
When this message is displayed on your device the course that you have created will have its course points automatically reduced keeping critical points in place to allow the unit to continue navigating properly.
How Can I Avoid This Issue?
You can avoid having this issue on your device by taking one of the following steps.
Reduce the number of manually added course points
Watches that support courses generally support up to 50 course points. Edge® cycling computers support up to 200.
Break up your course by creating two or more courses for instance.
