Monitoring C-Zone Digital Switching circuits
The C-Zone digital switches will be available on any GPSMAP 8xxx or GPSMAP 76xx/74xx series chart plotters with current software versions. In order to access the switch information you must have the switches connected then do the following on the display unit:
- Press Settings at the bottom of the screen
- Press Info at the bottom of the screen
- Select Circuit Control from the list
This will allow you to see your switches in a digital fashion on the display itself. In order to edit the switches themselves:
- Select My Vessel from the list
- Select CZone
- Choose the option from the list which you would like to edit
Once all of this is set up, the CZone switches will be visible and manageable on the chart plotter.
