Changing an inReach Device Address
Your inReach® device address is automatically generated by the email address used when initially creating your inReach account. For more information, see Related at the bottom of the page.
When you change the email address within your account using the steps below, the inReach address may also change as a result. Confirm that all of your inReach contacts have your correct inReach device address.
Due to this and the inReach Consumer Terms and Conditions, it is not recommended to allow others to change your inReach account information when lending out your inReach device. For more information, see - Borrowing or Lending Out an inReach Handheld
NOTE: You can only change your account email address to an email that is not already in the inReach system.
- Log into explore.garmin.com.
- Select the Account page.
- Select Edit next to your name under the My Info tab.
- Change the email address under the Email box.
- Select Done.
- Sync your inReach handheld. Refer to the links below for your device.
- Alpha® 200i - Syncing an Alpha 200i With the Garmin Explore™ Website and App
- GPSMAP® 66i, 86i, or 86sci - Syncing a GPSMAP 66i/86i/86sci With the Garmin Explore Website and App
- GPSMAP® 67i - Syncing a GPSMAP 67i With the Garmin Explore Website and App
- inReach Messenger - Simply connect it with the Garmin Messenger™ app on a smartphone. Any account related changes will automatically be synced to the inReach Messenger when it is connected and the phone has a data connection. For steps, see - Pairing an inReach Messenger With a Smartphone.
- inReach Mini, inReach SE®, inReach Explorer®, inReach SE+, or inReach Explorer+ - Updating inReach Firmware and Syncing Account Changes with inReach Sync
- inReach Mini 2 - Syncing the inReach Mini 2 With the Garmin Explore Website and App
- Montana® 700i or 750i - Syncing a Montana 700i/750i With the Garmin Explore Website and App
If the inReach Address changed after step 5 above, you should see that change reflected on your inReach device after syncing.
