Jumpmaster feature information
Jumpmaster is designed for experienced skydivers, particularly those in the military. It provides detailed information of speed of descent and altitude for experienced skydivers.
Jumpmaster allows you to set one of three types of jumps:
  • High Altitude-High Opening (HAHO)
  • High Altitude-Low Opening (HALO)
  • Static Jumps
You will be able to customize the settings for your jump including the Desired Impact Point (DIP) and wind set up. As the altitude information is based on the Barometric Altimeter, you will need to ensure this is fully calibrated before use. For detailed information on setting up your device for Jumpmaster refer to your device's user manual or for older models like the Foretrex 401 or some older eTrex models use the Jumpmaster's manual for more information. The tactix owner's manual in particular has a great deal of detailed information on the features of Jumpmaster.
