Garmin Products That Feature BirdsEye Direct Satellite Imagery
BirdsEye Direct Satellite Imagery is a preloaded service that allows you to download detailed satellite imagery from around the world directly to your device when it is connected to a Wi-Fi network, with no annual subscription.
  • Garmin offers the most recent images that our BirdsEye providers make available.
  • You can typically expect an update once a year in heavily populated areas. An update can usually be seen every two years in lesser populated areas. Updates to less populated areas do not apply to all regions, some regions may experience longer time-frames between updates.
    • These time-frames are estimated and there is no notification when an area will be, or has been, updated.
Select your device below for more details on how to use this feature.
Compatible Products
