Alpha 10
Alpha 200
Alpha 200i
Alpha 300
Alpha 300i
Device Compatibility With the Garmin Explore App
The Garmin Explore™ app allows you to sync a device for trip planning and activity review without requiring a data connection.
For more information about the Garmin Explore app, see Related.
NOTE: A compatible Garmin device is required to sync waypoints, routes, tracks, or activities with the Garmin Explore app and website. It is not required to have a compatible Garmin device to log in to the mobile app, download maps to the app, or sync data between the website and app.
Choose an option below to reveal a list of compatible models.
D2 Charlie
D2 Delta
D2 Delta PX
D2 Delta S
D2 Mach 1
- D2 Mach 1 Pro
Descent™ G1 | Descent™ G1 Solar | Descent™ G1 Solar - Ocean Edition
Descent™ Mk2 | Descent™ Mk2i | Descent™ Mk2S
- Descent™ Mk3 – 43 mm | Descent™ Mk3i – 43 mm | Descent™ Mk3i – 51 mm
Enduro
Enduro 2
epix™ (Gen 2) - Standard Edition 47 mm| epix™ (Gen 2) - Sapphire Edition 47 mm | epix™ (Gen 2) - Porsche Edition
epix™ Pro (Gen 2) - Standard Edition 42 mm| epix™ Pro (Gen 2) - Sapphire Edition 42 mm
epix™ Pro (Gen 2) - Standard Edition 47 mm| epix™ Pro (Gen 2) - Sapphire Edition 47 mm
epix™ Pro (Gen 2) - Standard Edition 51 mm| epix™ Pro (Gen 2) - Sapphire Edition 51 mm
eTrex SE
- eTrex Solar
fēnix® 5S | fēnix® 5 | fēnix® 5X
fēnix® 5S Plus | fēnix® 5 Plus | fēnix® 5X Plus
fēnix® 6 - Standard Edition | fēnix® 6 - Solar Edition | fēnix® 6 - Pro and Sapphire Editions | fēnix® 6 - Pro Solar Edition
fēnix® 6S - Standard Edition | fēnix® 6S - Solar Edition | fēnix® 6S - Pro and Sapphire Editions | fēnix® 6S - Pro Solar Edition
fēnix® 6X - Pro and Sapphire Editions | fēnix® 6X - Pro Solar Edition
fēnix® 7 - Standard Edition | fēnix®7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix Chronos
NOTE: Forerunner watches will have limited functionality with the courses feature in conjunction with the Garmin Explore app.
Forerunner 935
Forerunner 945
Forerunner 955 | Forerunner 955 Solar
Foretrex 801
Foretrex 901 Ballistic Edition
GPSMAP 64s
GPSMAP 64csx
GPSMAP 64sc
GPSMAP 64st
GPSMAP 64sx
GPSMAP 65
GPSMAP 65s
GPSMAP 66i
GPSMAP 66s
GPSMAP 66sr
GPSMAP 66st
GPSMAP 67
GPSMAP 67i
GPSMAP 86i
GPSMAP 86s
Alpha 200i
Alpha 300i
GPSMAP 66i
GPSMAP 67i
GPSMAP 86i
GPSMAP 86sci
inReach Mini 2
Montana 700i
Montana 750i
Instinct® - Standard Edition | Instinct® - Tactical Edition | Instinct® - Esports Edition
Instinct® Solar - Standard Edition | Instinct® Solar - Camo Edition | Instinct® Solar - Surf Edition | Instinct® Solar - Tactical Edition
Instinct® 2 - Standard Edition | Instinct® 2 - Camo Edition | Instinct® 2 - Surf Edition | Instinct® 2 - dēzl Edition
Instinct® 2 Solar | Instinct® 2 Solar - Tactical Edition | Instinct® 2 Solar - Surf Edition
Instinct® 2S - Standard Edition | Instinct® 2S - Camo Edition | Instinct® 2S - Surf Edition
Instinct® 2S Solar | Instinct® 2S Solar - Surf Edition
Instinct® 2X Solar | Instinct® 2X Solar - Tactical Edition
Instinct® Crossover - Standard Edition | Instinct® Crossover Solar | Instinct® Crossover Solar - Tactical Edition
MARQ® Adventurer | MARQ® Athlete | MARQ® Aviator | MARQ® Captain | MARQ® Commander | MARQ® Driver | MARQ® Expedition | MARQ® Golfer
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
Montana 700
Montana 700i
Montana 750i
Overlander GPS navigator comes pre-installed with an onboard Garmin Explore app, but cannot be paired directly to the Garmin Explore smartphone app. The Garmin Explore smartphone app can still be used to manage data and the Overlander will sync the Garmin Explore data when connected to Wi-Fi.
Pro 550 Plus
quatix® 5 | quatix® 5 Sapphire
quatix® 6 | quatix® 6 Titanium | quatix® 6X Solar
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition
- quatix® 7 Pro
tactix® Delta - Sapphire Edition | tactix® Delta - Solar Edition | tactix® Delta - Solar Edition with Ballistics
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Edition | tactix® 7 - Pro Ballistics Edition
NOTE: These devices come pre-installed with Garmin Explore app information. They are not compatible with the Garmin Explore smartphone app. Garmin Explore data is synced with the Tread® app.
Kawasaki RIDGE 8" Tread Display
Tread® GPS navigator
Tread® - Base Edition GPS navigator
Tread® - Overland Edition GPS navigator
Tread® XL - Overland Edition GPS navigator
Tread® - SxS Edition GPS navigator
Tread® XL - Baja Chase Edition GPS navigator
Tread® XL - Baja Race Edition GPS navigator
zūmo XT
zūmo XT comes pre-installed with Garmin Explore information. It is not compatible with the Garmin Explore smartphone app. Garmin Explore data is synced with the Garmin Drive™ smartphone app.
zūmo XT2
zūmo XT2 comes pre-installed with Garmin Explore information. It is not compatible with the Garmin Explore smartphone app. Garmin Explore data is synced with the Tread app.
