Navigational Avoidances on a Chrysler, Dodge, Jeep, or RAM UConnect System
Chrysler UConnect Systems with Garmin navigation have an Avoidance menu where you can select various options that will adjust how your device routes you. Items with a check mark beside them will be avoided whenever possible.
To locate the Avoidance menu:
1. Touch Nav or Navigation to access the navigation menus
2. Touch Settings
3. Touch Navigation
4. Touch Enabled or Disabled beneath avoidances
5. Touch the desired Avoidance to enable it
Repeat the steps above to disable the checked Avoidance.
Available avoidances:
- U-Turns – Avoids calculating routes that require a U-turn
- Highways – Avoids highways, interstates, freeways, motorways, and other major routes
- Toll Roads – Avoids toll roads and certain specified congestion zones
- Ferries – Avoids routes that require a ferry crossing
- Carpool Lanes – Avoids lanes designated specifically for carpooling
- Unpaved Roads – avoids unpaved roads (gravel, dirt, etc.)
Note that devices will only avoid selected items when it is possible. For example, if you have U-Turns selected as an avoidance the device may still direct you to make a U-Turn if an alternate route is not available.
