- Sur l'inReach Mini, appuyez sur OK pour ouvrir le menu principal
- Sélectionnez Configurer
- Sélectionnez Bluetooth
- Sélectionnez Coupler l'appareil
- Ouvrez Earthmate sur votre appareil iOS
- Connectez-vous si nécessaire
- Touchez Autre
- Touchez Options
- Touchez Coupler l'appareil
- Touchez Garmin inReach Mini
- Touchez Connecter
- Appuyez sur l'appareil inReach dans la liste sous Sélectionner un accessoire
REMARQUE : Cela peut prendre de 1 à 2 minutes pour que l'appareil apparaisse dans la liste
Pairing an inReach Mini With a Phone or Tablet
The inReach® Mini satellite communicator can be paired with a mobile device to compose, send, and receive messages using the interface of your mobile device.
Using the inReach Mini with your mobile device will require the Earthmate® app.
If you are pairing a device that is not your original device, you may see the following error:
This message is referencing the data on the device, rather than the account data in the Earthmate app. The replacement device is syncing with the account for the first time, therefore, data on the device can be overwritten by account data syncing over. When this pairing is complete, some data may stay on the device, while other data may get overwritten by the account's data.
If you are concerned about losing data we recommend verifying if the data appears on the map tab on your account at explore.garmin.com. If the data is not showing, your original device would need to be synced before transferring service to a different device and pairing it to Earthmate. For steps, see - Updating inReach Firmware and Syncing Account Changes with inReach Sync.
NOTE: The inReach Mini device will pair and work with both the Earthmate app and Garmin Pilot™ app at the same time on the same phone, but it can only be paired to one phone at a time.
