Registering a vivofit jr. 2 Accessory Band
Included with the purchase of a vivofit jr. 2 accessory band is a code that unlocks a corresponding app adventure:
To unlock an adventure, you must purchase then register the accessory band.   The steps below will outline the process of registering the band:
  1. Locate the unlock code that came with your accessory band
  2. Open the vivofit jr. mobile app and select the Kid Profile you want to register the accessory band to.
  3. At the bottom of the screen touch Register an Accessory Band.
  4. Input Unlock Code from the sheet then touch Continue.
  5. Confirm Adventure Map by touching Register Now.
  6. Touch Change Now.
  7. Touch the new Adventure Map that was unlocked and then touch Change.
At this point you can back out of the user settings and begin using the new Adventure Map from the child's dashboard.
