Showing and Hiding Items on the Garmin Explore Website Map
The Garmin Explore™ website map page has many controls for filtering or toggling item visibility from the map itself. This can be helpful for showing or hiding specific items to declutter the map.
Toggle Visibility for Items on the Map
The Garmin Explore website map features the ability to toggle visibility of certain categories and collections within the Library.
  • Garmin Explore Website Map Category Showing to the right of the category or Collection name indicates those items are currently toggled on and showing.
  • Garmin Explore Website Map Category Hidden to the right of the category or Collection name indicates those items are currently toggled off and hidden.
There is a hierarchy with the Library and Collections for toggling item visibility. All data items are stored in the Library and then further organized into Collections. The Library section contains all of your Waypoints, Tracks, Routes, Activities, and Courses. If a category is set to Garmin Explore Website Map Category Hidden then all items in that category will be hidden, even if some of the items are in a Collection that is set to Garmin Explore Website Map Category Showing. This is because the visibility toggle for Library categories takes precedence over the visibility toggle for Collections. See the examples below for more information.
Examples of Toggling Item Visibility
Example 1
In the below image, the Waypoints category in the library is set to Garmin Explore Website Map Category Hidden. These waypoints are stored in the Library and further organized into the Sent to MapShare™ collection which is set to Garmin Explore Website Map Category Showing.
Garmin Explore Website Map Library Waypoints Hidden
Result: All waypoints are now hidden from the map. The waypoints that are in the Sent to MapShare Collection are hidden from the map with this setting because the visibility toggle for the waypoints category in the Library takes precedence over the Sent to MapShare visibility toggle.
Example 2
In the next image below, the Sent to MapShare Collection is set to Garmin Explore Website Map Category Hidden and the Waypoints category in the Library is set to Garmin Explore Website Map Category Showing.
Garmin Explore Website Collection Hidden
Result: Only the waypoints in the Sent to MapShare Collection are now hidden from the map. Any other waypoints not in the Sent to MapShare Collection are still showing on the map because the waypoints category in the Library is still set to show on the map.
NOTE: If the item you are trying to hide is in multiple Collections, all Collections containing that item need to be hidden.
Toggle Track Visibility:
By default, all tracks are set to appear on the map tab of the Garmin Explore website. If your track summary appears in the library, but does not appear on the map when selected, you may need to toggle the visibility on.
  1. Select Target with black circle to center the map on the user.
  2. Select Plus sign in a circle so that the track expands.
Last Synced Location on the Explore Website Map Tab
Once this is done, the icon should now be Minus sign in a circle.
Using the Map Filters
The Map Filters allow for showing or hiding specific message types. These filters also allow for filtering tracks and message types by date and time ranges.
Message Types That Can Be Hidden or Shown
  • Locate: Location requests.
  • Messages: Messages sent from the inReach®.
  • Track Points: Track points sent from the inReach.
  • Navigation: Navigation to a waypoint.
  • Reference Points: Reference point locations sent from an inReach SE®+/Explorer®+.
  • MapShare: MapShare link messages sent from the inReach.
Example of Using the Message Types Filter
  1. Log in to the Garmin Explore website.
  2. Select Map.
  3. Select Message Types.
    Garmin Explore Website Message Types
    NOTE: If you do not see Message Types, select Garmin Explore Website Map Filters to open the Map Filters options.
  4. Select the desired check boxes to hide or show messages types.
    Garmin Explore Website Message Type Filters
    In this example, Messages are hidden from the map and all other items are showing.
Date And Time Range Filter Options
NOTE: The Date and Time range filters only filter tracks and the Message Types referenced above.
  • All Time: Shows all tracks.
  • Currently Tracking: Shows only the current track.
  • Most Recent Track: Shows only the most recent track.
  • Last 24 Hours: Shows only the last 24 hours of tracks.
  • Last 7 Days: Shows only the last 7 days of tracks.
  • Custom Date Range: Allows for entering a specific date and time range for filtering tracks.
Items Not Affected By the Date And Time Range Filter
  • Waypoints.
  • Routes.
  • Activities.
  • Courses.
Example of Using the Date And Time Range Filter
  2. Select Map.
  3. Select the drop down box under Date & Time Range.
    Garmin Explore Website Map Date and Time Filters
    NOTE: If you do not see the drop down box, select Garmin Explore Website Map Filters to open the Map Filters options.
  4. Select an option.
    Garmin Explore Website Map Date and Time Filter Most Recent Track
    In this example, only the most recent track is showing on the map.
    Custom Date Range
    If Custom Date Range is selected:
    1. Select Edit to change the date and time range.
      Garmin Explore Website Map Custom Date Range
    2. Enter a custom date and time range and select Done when finished.
      Garmin Explore Website Map Customer Date Range Done
    Only tracks and message types between the custom date and time range will be shown now.
To clear the Date & Time Range filter, select Garmin Explore Website Map Clear Filters.
Sujets connexes
