L'article présenté sur cette page n'est pas disponible dans la langue que vous avez sélectionnée. Vous pouvez en choisir une autre ci-dessous.
Setting up the Dexcom Connect IQ Data Field
Once the Dexcom Data Field has been downloaded from the Garmin Connect IQ™ store, there are some steps to complete in order to see your glucose number recorded by your Dexcom Continuous Glucose Monitoring System on your Garmin device. The Dexcom apps in the Connect IQ Store are software-only applications for compatible Garmin smartwatches and Edge® cycling computers, intended to provide a secondary display of continuous glucose monitoring (CGM) data to users of compatible Dexcom continuous glucose monitors for the purposes of passive monitoring.
The Dexcom Data Field shows blood glucose levels and trends during an activity on your compatible Garmin device. Below are samples of what you may see along side your activity information:
To complete the setup, your Garmin device must be connected in the Garmin Connect™ app on your smartphone. For pairing instructions, refer to your owner's manual.
Select your device below to reveal instructions for setting up the Dexcom Connect IQ data field:
D2™ Air X10 Watch
Press Start and select an activity profile.
Swipe up to access the profile settings.
Select Settings.
Select Data Screens.
Select a screen to customize.
Select Edit Data Fields.
Select a data field to customize.
Select Connect IQ Fields.
Select Dexcom Data Field.
Press the back button four times to return to the activity profile home page.
Swipe up to access the profile menu.
Select OK to begin the sign-in process.
Scroll through and accept Usage Notice.
Open the Garmin Connect app when prompted.
Android: The Dexcom login page automatically opens.
iOS: Select Sign In on the Dexcom login prompt.
Sign in with your Dexcom username and password.
Accept the usage terms and e-sign.
Return to your watch to complete the sign-in process.
You have now enabled the Dexcom data field on your watch.
Edge® Cycling Computers
Edge® 530
From the home screen, press the Down button to access the menu.
Select Settings.
Select Activity Profiles.
Select a profile.
Select Layout and Data Fields.
Select a layout.
Select Connect IQ.
Select Yes to edit data field settings.
Scroll through and accept the Usage Notice.
Android: The Dexcom login page opens automatically.
Return to your Edge to complete the sign-in process.
You have now enabled the Dexcom data field on your Edge 530.
Edge® 540 | Edge® 540 Solar | Edge® 830 | Edge® 840 | Edge® 840 Solar | Edge® 1030 | Edge® 1030 Plus | Edge® 1040 | Edge® 1040 Solar | Edge® Explore 2
From the home screen, press to access the menu.
Select a profile.
Select the screen you want to customize.
Select a layout.
Select Connect IQ.
Select the checkmark to edit the data field settings.
You have now enabled the Dexcom data field on your Edge.
Edge® 1050
Select to access the menu.
Select a profile.
Select to confirm layout.
Select the location of the field you would like.
Select Connect IQ.
Select to confirm the data field settings.
You have now enabled the Dexcom data field on your Edge 1050
Forerunner® Watches
Select the Start button and select an activity profile.
Select and hold the Up button to access the profile settings.
Select the profile settings (Example: Run Settings).
Select Data Fields.
Select a field to customize.
Select Start to edit the data field settings.
Select Down to begin the sign-in process.
Outdoor Watches
D2™ Watches
D2™ Delta | D2™ Delta PX | D2™ Delta S
Select START/STOP and select an activity profile.
Hold UP to access the profile settings.
Select Data Fields.
Press START/STOP to edit data field settings.
Press DOWN to begin the sign-in process.
D2™ Mach 1 | D2™ Mach 1 Pro
Select Data Fields.
Enduro™ | Enduro™ 2 | Enduro™ 3
Select START/STOP (upper right button) and select an activity profile.
Hold UP (middle left button) to access the profile settings.
Select Data Fields.
Press START/STOP (upper right button) to edit data field settings.
Press DOWN (lower left button) to begin the sign-in process.
Select START/STOP (upper right button) and select an activity profile. (Example: Run)
Select Activity Options or "Activity Name" Settings. (Example: Run Settings)
Select Data Fields
Select Dexcom Datafield.
Select START/STOP to edit data field settings.
Select DOWN (lower left button) to begin the sign-in process.
Venu® Watches
The steps below applies to all Venu models.
Select Settings.
vívoactive® 4 | vívoactive® 4S
Select Settings.
IMPORTANT: Updated information will only be provided when your compatible smartphone has a data connection and is in BLE range of both the Dexcom CGM and Garmin smartwatch or Edge® cycling computer. For more details, visit the Dexcom CIQ app page.
Dexcom Data Field Instructional Video for an Edge Cycling Computer
Dexcom Data Field Instructional Video for an Outdoor Watch
Dexcom Data Field Instructional Video on a Wellness Watch
