Instructions to Sync Spotify Music to the Descent Mk2 Series
This article will provide instructions to use the Spotify Connect IQ app on the Descent Mk2 Series.
Requirements
The following are requirements to use the Spotify Connect IQ app on your watch:
I Meet the Requirements - What's Next?
Step 1: Initial Setup of the Spotify Connect IQ App
  1. Press and hold Down
  2. Next, you will be prompted to select your music provider. Press Down
  3. Select Spotify
  4. You will now be prompted to open the Garmin Connect app
  5. From the Garmin Connect app, you should see a Spotify login prompt
  6. Enter your Spotify login details and select LOG IN
  7. Review and agree to the terms by selecting AGREE
  8. Return to your watch and select Get Started
  9. Choose the option to Add music & podcasts
From this point you will be able to choose saved Playlists, Recently played, Made for You, Workouts, or Podcasts. If you have not previously used Spotify for your music proceed to Step 2 to get some music set up to send to your watch.
Step 2: Selecting and Syncing Content to the Descent Mk2 Series
NOTE:
The watch must be able to connect to your Wi-Fi network to download content from Spotify. Content available to sync to the Descent Mk2 Series will be listed under Your Library from your Spotify account. This includes:
  • Playlists: Saved or created playlists
  • Recently Played: A list of tracks that you have recently played
  • Made for you: New Music and Daily Mixes based on your listening habits
  • Podcasts: Saved podcasts
  1. On the watch access the Music Controls (press and hold Down
  2. Select Add music & podcasts
  3. Choose a category then choose the content you want to sync to your watch
At this point, the watch will attempt to connect to your Wi-Fi network to sync music. Syncing music will require a lot of battery power so we recommend plugging the watch into a charger near the Wi-Fi router for the best results.
Sujets connexes
