Wireless Map and Software Update Instructions
To successfully complete a Wi-Fi update, a wireless connection to home high-speed internet (Fiber, Cable, DSL, etc.) is required.  Due to the size of a map update, connections with data caps or restrictions should not be used. Slower connections (satellite, fixed wireless, dial-up, etc.) and mobile broadband (MiFi, AirCard, cell phone tethering, etc.) should not be used.
To check for and install both software and map updates on this device:
1. Touch dezl 78x settings gear transparent v2 or overlander settings icon
2. Touch About Device
PND Android settings - about device
3. Touch System Updates
PND Android settings - system updates cropped
4. If prompted, touch Access Wi-Fi Settings. If your device is already connected to a wireless network, skip to step 9
5. If prompted, enable Wi-Fi by touching the toggle switch and changing it from Android - toggle disabled Off to Android - toggle enabled On
PND Android settings - enable wifi
6. Select the desired wireless network. A network labeled Garmin is shown as an example, but you may select your personal wireless network.
PND Android settings - select wifi network
7. If necessary, enter the password for the network
PND Android settings - wifi sign-in
The device should then connect to the network, and the network will be added to the list of saved networks. The device will reconnect to this network automatically when it is within range.
8. Press the Android back arrow back arrow
PND Android settings - wifi - go back
9. The device will check for any available updates over a Wi-Fi network. If updates are available, they will be displayed on this page.
Press Map to view information about and start the map update, or Software to view information about and start the software update.
PND Android - updates available
To begin downloading all updates, press Download, then OK.
Note: The device will be unusable until the updates complete.
If the device encounters any problems with the wireless update, see  Troubleshooting Wireless Updates on the dezl 780, dezlCam 785, Overlander, or Camper/RV 785.
You may also update your device by using Garmin Express.  See  Updating Automotive Maps and Software with Garmin Express.
