How Do I Disable Certain Notifications on My Garmin Device?
Controlling which notifications you do not want to see on your Garmin device is managed from your phone. Choose your phone type below to reveal instructions.
Android
  1. Open the Garmin Connect™ app.
  2. Select More (bottom right).
  3. Select Settings.
  4. Select Notifications.
  5. Select App Notifications.
From here, toggle Toggle off notifications off to disable individual apps.
iOS
The following settings are for phones running iOS 16 or higher. To ensure the best possible compatibility between your phone and your Garmin device, make sure that your phone's operating system is up to date.
IMPORTANT: You will need to follow the steps below for each app you want to disable notifications for. Below is an example for Messages.
  1. From the iPhone Settings, select Notifications.
  2. Select an application you do not want to receive notifications from. Example: Select Messages.
    1. Remove the Blue Checkmark screenshot checkmark from the Notification Center alert.
    2. Set Show Previews to "Never (Default)".
Following the steps above will result in your phone looking like the example below. Repeat these steps for each app that you want to stop receiving notifications from on your Garmin device.
iOS Notification Settings Screenshot
Sujets connexes
