What is Automatic Interval Categorization?
When going for a run, select watches can generate intervals by utilizing the lap button. This can be helpful for instances when you did not create a custom interval workout.
Watches compatible with the Automatic Interval Categorization feature will categorize your laps as warm-up, run, or rest periods once the activity is uploaded to Garmin Connect™. Pace will become a factor to determine your intervals.
How Do I Start an Interval Workout on My Watch?
The following steps should work for most watches. For specific instructions for your watch, see “Starting an Interval Workout” in your owner's manual.
For select models, you can enable Open Repeats under the Run activity profile to track intervals on your watch.
Select the Run profile on your Watch.
Select Training or press
MENU then select Training.
Select Quick Workout.
Select Intervals.
Select Open Repeats.
Confirm if you want to start with a warm-up or not.
From here, use the BACK/LAP button to transition between interval and rest periods.
Compatible Watches:
D2™ Mach 1 | D2™ Mach 1 Pro
Descent™ Mk3 | Descent™ Mk3i
Enduro™ 2
Enduro™ 3
epix™ (Gen 2) - Standard Edition | epix™ (Gen 2) - Sapphire Edition
epix™ Pro (Gen 2) - Standard Edition | epix™ Pro (Gen 2) - Sapphire Edition
fēnix® 7 - Standard Edition | fēnix® 7 - Solar Edition | fēnix® 7 - Sapphire Solar Edition
fēnix® 7S - Standard Edition | fēnix® 7S - Solar Edition | fēnix® 7S - Sapphire Solar Edition
fēnix® 7X - Solar Edition | fēnix® 7X - Sapphire Solar Edition
fēnix® 7 Pro - Solar Edition | fēnix® 7 Pro - Sapphire Solar Edition
fēnix® 7S Pro - Solar Edition | fēnix® 7S Pro - Sapphire Solar Edition
fēnix® 7X Pro - Solar Edition | fēnix® 7X Pro - Sapphire Solar Edition
fēnix® 8 - AMOLED Edition | fēnix® 8 - Solar Edition
fēnix® E
Forerunner® 255 | Forerunner® 255S | Forerunner® 255 Music | Forerunner® 255S Music
Forerunner® 265 | Forerunner® 265S
Forerunner® 570
Forerunner® 945 | Forerunner® 945 LTE
Forerunner® 955 | Forerunner® 955 Solar
Forerunner® 965
Forerunner® 970
MARQ® Adventurer (Gen 2) | MARQ® Athlete (Gen 2) | MARQ® Aviator (Gen 2) | MARQ® Captain (Gen 2) | MARQ® Golfer (Gen 2)
MARQ® Adventurer (Gen 2) - Damascus Steel Edition | MARQ® Athlete (Gen 2) - Carbon Edition | MARQ® Athlete (Gen 2) - Performance Edition | MARQ® Commander (Gen 2) - Carbon Edition | MARQ® Golfer (Gen 2) - Carbon Edition
quatix® 7 - Standard Edition | quatix® 7 - Sapphire Edition | quatix® 7X - Solar Edition | quatix® 7 Pro
tactix® 7 - AMOLED Edition | tactix® 7 - Standard Edition | tactix® 7 - Pro Ballistics Edition | tactix® 7 - Pro Edition
tactix® 8 - AMOLED | tactix® 8 - Solar
Venu® X1
