Getting Started With Outdoor Maps Plus on a Garmin Watch
With an Outdoor Maps+ annual subscription, you gain access to a wide variety of premium global mapping content. Examples of the mapping available can be viewed in the related content. This content is regularly updated and a single subscription can be activated and downloaded directly to your watch or any of your registered compatible Garmin devices simultaneously via Wi-Fi. For details on map coverage and the types of mapping that are available, see - Outdoor Maps Plus Premium Mapping Types.
It is important to purchase the subscription using the same email address as the one tied to your Garmin Connect account. The topics below explain how to activate, download, and use the different types of mapping content that are available with Outdoor Maps+.
NOTE: To use Outdoor Maps+ the watch software must be up to date. For instructions, see - Help with Product Updates.
Topics
Activating Outdoor Maps+
REMARQUE : Ces appareils nécessitent le logiciel le plus récent pour être pleinement compatibles.
After purchasing an Outdoor Maps+ annual subscription, it needs to be activated on your watch. Please make certain that your watch is paired to the same Garmin Connect account on your smartphone that was used to purchase the map subscription. The video below will walk you through the steps for activating and downloading map content to your watch.
Steps for Activating Outdoor Maps+
The steps below tell you how to activate your Outdoor Maps+ subscription on your watch.
  1. Press START/STOP.
  2. Select Map Manager.
  3. Select Outdoor Maps+.
  4. Press START/STOP to proceed past the QR code. If you have not purchased a subscription, scanning the code will take you to the product purchase page.
  5. Select Check Subscription.
  6. Wait for the activation to complete.
Once the activation completes, you can proceed with downloading Outdoor Maps+ content to the watch.
Back to Top
Setting Up Wi-Fi
In order to download Outdoor Maps+ content, the watch must connect to a Wi-Fi network. Please see Adding, Removing, and Troubleshooting Wi-Fi Networks With a Compatible Garmin Outdoor Watch for requirements and instructions on how to set up Wi-Fi on your watch.
Back to Top
Downloading Outdoor Maps+ Content
After activating an Outdoor Maps+ annual subscription, you can download maps to the watch via Wi-Fi. The video above goes through the steps for downloading Outdoor Maps+ content starting from here, and the full instructions for downloading maps are included below. These steps can be repeated to download multiple different map areas.
Steps to Download Outdoor Maps+ Content
These steps are how you can download Outdoor Maps+ content to your watch.
    NOTE: If necessary, press START/STOP and select Check Subscription
  4. Select +Add.
    The watch will display Requesting Map Update Data while it connects to Wi-Fi.
  5. Select an option.
    • Current Location: allows you to browse the map of your current location.
    • Points of Interest: allows you to browse the map around nearby points of interest.
    • Saved Location: allows you to browse the map around a saved location.
  6. Press START/STOP to confirm the map area you would like to install.
  7. Press Down to edit the map download options.
    • Map Name: allows you to name the map. Use the on screen keyboard or the Instant Keyboard on your connected smartphone.
    • Layers: allows you to edit which layers will download. Select More Info and then select a layer to learn more about what that layer will show.
    • Selected Area: allows you to change the size or location that is selected. Hold Menu to access pan and zoom controls. Press START/STOP to switch between zoom in or out, pan up or down, pan left or right using the Menu and Down buttons.
    • Done: returns you to the map download screen after making edits.
  8. Press START/STOP to queue the download.
  9. Plug in the watch.
  10. Press START/STOP to begin map download.
The download will remain queued until the watch is plugged in. While the download is in progress, it is important to have the watch plugged in and in range of the connected Wi-Fi network. Depending on the speed of the Wi-Fi network and the size of the file, each download may take a while to complete.
  Back to Top
Enabling or Disabling Specific Outdoor Maps+ Content
You can choose what layers show while using the map by configuring them through the map settings in your activity. You will need to have the TopoActive map for your region installed in order to show all Outdoor Maps+ details. To download TopoActive maps see Using Map Manager on Garmin Watches. Outdoor Maps+ layers need to be configured for each activity you wish to use the additional map data in.
  1. Hold Menu.
  2. Select Activities & Apps.
  3. Select the activity you wish to configure (ex: Run).
  4. Select the activity settings (ex Run Settings).
  5. Select Map Layers.
  6. Select the layers you want enabled.
Back to Top
Deleting Maps
If you wish to delete Outdoor Maps+ content for any reason, follow the steps below.
  4. Select the map you wish to delete.
  5. Press START/STOP.
  6. Select Delete.
After completing these steps, the selected content will be removed from the watch.
Back to Top
Managing Your Subscription
When purchasing an Outdoor Maps+ annual subscription, there is an option to enable automatic annual renewal. If you need to update your payment information, cancel automatic renewal, this can be done by visiting garmin.com/subscriptions and signing into your Garmin account. For more details, see Managing My Outdoor Maps Plus Annual Plan.
Back to Top
Sujets connexes
