Outdoor Handheld Fails to Sync Successfully Using Garmin Express
If Garmin Express fails to sync with an outdoor handheld that communicates through a USB data cable, follow the troubleshooting steps below:
- Ensure that Garmin Express is up to date (see Updating the Garmin Express Application Software)
- If Garmin Express states that the device is not connected, follow the troubleshooting information in the following FAQ:
- Ensure that the software is up to date on the Garmin outdoor handheld device (see Installing Software Updates to Outdoor/Marine Handhelds)
- If there is no Sync button available, check the Upload Preferences in Garmin Express to ensure that consent has been given to upload data to Garmin Connect:
- Select your device
- Select Tools & Content
- Select the Privacy tab
- Select Change Upload Preferences
- If Garmin Express displays a server error, follow the troubleshooting information in the following FAQ: Garmin Express Displays a Server Error Message
- If there are corrupt files on the device, Garmin Express may display the error Some files could not be uploaded to Garmin Connect as shown below:
If this error occurs, proceed with the following steps:- Manually Upload all of the activities from the device to Garmin Connect. For instructions, see - How Do I Manually Upload an Activity I Recorded to Garmin Connect?
- Delete the activity files from the device. For instructions, see - Removing Recorded Activities to Free Up Space on a Garmin Fitness Device
- Clear the upload history in Garmin Express:
- Select Utilities
- Scroll down to "Clear Upload History" and select Clear History
- Select Continue
If issues persist, contact Product Support.
