How Do I Edit Contacts in the Garmin Connect App?
Adding personal contacts to the Garmin Connect™ app is an important step to utilize features that Garmin offers such as Incident Detection, Live Event Sharing, and Safety Assistance.
To Add or Edit Contacts:
Open the Garmin Connect App.
Select More (bottom right).
Select Contacts.
View, create, or edit contacts here:
Create A Connect Contact:
Select Phone or Create a Connect Contact to add to the Contact list.
Edit a Contact:
Select the person you want to edit.
Select Edit.
Make Changes.
Select Save.
To Remove Contacts:
Select Contacts.
Select the contact you wish you to remove.
Select Edit.
Select Delete Contact.
Confirm you want to remove the contact.
Your Contacts list will reflect the changes you have made.
Deleting a contact removes it from the features requiring the contact. If the person is a Connection and you want to remove them, see Add and Remove Connections in Garmin Connect
