How Do I Align the Watch Hands on a vivomove Watch?
If the watch hands on your vivomove series watch are not correct, it may be necessary to align them. This can be done through the Garmin Connect app or directly on the watch. Choose your option below to reveal instructions.
Align Using the Garmin Connect App
The watch must be connected to the Garmin Connect app to align the hands using the Garmin Connect app.
NOTE: This option does not apply to the original vivomove model. See steps in the next section to adjust the watch hands through the watch settings.
  1. Open the Garmin Connect app.
  2. Open the menu.
    • Android: Select Garmin Connect Android menu icon (top left)
    • iOS: Select More (bottom right)
  3. Select Garmin Devices.
  4. Select your watch.
  5. Select Device Settings (only for vivomove HR).
  6. Select Hand Alignment.
  7. Align both the minute and hour hands on your watch to 12 o'clock by rotating the wheel or using the +/- buttons in the Garmin Connect app.
  8. Select Save.
vivomove alignment screen in Garmin Connect app
We also have provided the following video tutorial on the process:
Align Hands Through the Watch Settings
Instructions to align the hands using the watch can be found in the owner's manual. Choose your watch model below for instructions.
NOTE: The video does not apply to the original vivomove watch.
Sujets connexes
