Compatible Rangefinders and Pairing Them to a Foretrex 701 or 901
The Foretrex® 701 and 901 outdoor navigators can now receive range data1 automatically from compatible rangefinders as well as provides a ballistic solution back to the rangefinder.
  • Bushnell Nitro 1800
  • Leica Geovid Pro 10x42 AB Plus
  • Leica Geovid Pro 32
  • Safran Vectronix Terrapin X
  • Sig Sauer KILO 2400 BDX
  • Sig Sauer KILO 3000 BDX
  • Sig Sauer KILO 5K BDX
  • Sig Sauer KILO 8K-ABS
  • Sig Sauer KILO 10K-ABS HD
  • Vectronix Terrapin X
To take advantage of this feature, ensure the Foretrex device software is up to date via the Garmin Express™ program.
Pairing a Rangefinder
To pair a Foretrex 701 or 901 device to a rangefinder first put the compatible rangefinder in AB External pairing mode. Use the rangefinder's owner's manual for instructions.
  1. Press PAGE until you reach the menu page.
  2. Select CONNECT.
  3. Select APPLIED BALLISTICS.
  4. Select SEARCH FOR NEW.
  5. Select the rangefinder in the list.
Once paired, it will show as Connected under the Applied Ballistics menu.
1 Only range is supported.
Sujets connexes
