Pairing a Dog Tracking Collar to the Alpha 200 or Alpha 200i
Up to 100 compatible dog tracking collars can be paired to the Alpha 200/200i wirelessly using MURS/VHF, by entering the track and control codes, or by sharing wirelessly from another handheld using ANT+ technology. Up to 20 collars can be actively tracked at one time.
Adding a Dog Collar Wirelessly using MURS/VHF
To pair wirelessly, the collar should be within close proximity (approx. 10 feet) to the handheld and away from sources of interference.
  1. Ensure the removable antenna is installed on the Alpha 200/200i.
  2. Power on the Alpha 200/200i.
  3. Put the dog collar in pairing mode. For steps, choose your collar model below.
    null
  4. Select Dog List.
  5. Select Add Dog.
  6. Select Pair Collar.
  7. Use the keyboard to enter a dog name.
  8. Select Finish.
    NOTE: If you have other collars to add, select Add More.
The dog collar is now paired to the handheld. If pairing is unsuccessful, see - null.
Using Track and Control Codes to Add a Dog Collar
Dog collars can be paired to an Alpha 200/200i using track and control codes if the collar has already been paired to a different handheld. Track codes allow the Alpha 200/200i to track the collar; Control codes allow the handheld to both track and use training functions of the collar.
  1. Power on the Alpha 200/200i.
  2. Select Dog List.
  3. Select Add Dog.
  4. Select Enter Track or Control Code.
  5. Enter the track or control code for the collar.
    NOTE: For steps to find the share code for the collar, reference "Locating Track and Control Codes" below.
  6. Select Alpha 200i Check Mark
  8. Select Alpha 200i Check Mark
null
 Sharing a Dog Wirelessly from Another Dog Tracking Handheld
 A tracking collar can be shared wirelessly to an Alpha 200/200i from another handheld it is paired to.
  1. Select Dog List.
  2. Select Add Dog.
  3. Select Receive from Handheld.
  4. Share the dog from the other handheld. For steps, choose a model below.
    null
  5. Use the keyboard to enter a dog name.
  6. Select Finish.
    NOTE: If you wish to add more dogs, select Add More.
Compatible Dog Tracking Collars
  • TT 15X
  • TT 15
  • TT 15 mini
  • T 5X
  • T 5
  • T 5 mini
