Finding Saved or Recent Locations and Viewing them in a List or on a Map
When searching for locations, the device allows you to view the results in a list or on a map. You will see these options on many lists of results on your device, including in the Categories view and your Saved and Recent menus.
By default, the device will display search results as a list:
You can choose where you want to go from the list and begin to calculate a route, or save the address, by touching the desired destination.
To show search results on a map, press the button in the upper right corner highlighted above:
You can drag the map to view additional search results. Touch an icon to see information or to begin navigation.
To return to the list view, press the button in the upper right corner again.
