I Cannot See the Maps from the SD Card I Purchased in My Outdoor Handheld
If you purchased a preloaded microSD map card and are not seeing the detail on your Garmin outdoor handheld, this article goes over what to look for steps to resolve the issue.
This article only pertains to resolving issues with Garmin maps. If your map is from a third party manufacturer, contact them for assistance.
Troubleshooting a Map Card
- Make sure the microSD card is fully inserted and if applicable, that the door is locked: (VIDEO) Support: Adding a microSD card to a handheld device
- Ensure your device is up to date on its software. For steps, see:
- Verify that the map is enabled for viewing
Click Here for How to Enable Maps
- Power on the Garmin device
- Access the Main Menu
- Select Setup
- Select Map
- Select Configure Map or Map Information
- Enable the new map and disable other maps1
1BirdsEye imagery does not need to be disabled and the Worldwide DEM Basemap should always be enabled.
- If you have multiple maps installed, they fall into a hierarchy. Specifically, City Navigator maps take precedence over topographic maps so, it needs to be disabled for topographic detail to display
- Provided you have GPS signal, handhelds are designed to display your current location. If the map you want to view is for a different region than you are currently located, the map needs to be moved to that region to see it's detail
- On touchscreen devices, you can swipe directly on the map to move it around
- On non-touchscreen devices, you can use the thumbstick or arrow buttons to move it around
- Scroll around the map, and try zooming in and out between 20 feet and 2 miles
- Example: If you have a topographic map of Kansas and are in a very flat area of Kansas and zoomed in to around 40 feet, you may not see any elevation contour lines. Scrolling around and adjusting the zoom may show contour lines as elevation begins to change
- If it is possible the issue is with a map you downloaded, or one preloaded in your device, see Related
Note: You can also verify the map card by viewing it within Garmin BaseCamp. For steps, see - View Preloaded Maps, Preprogrammed microSD/SD Cards, and Downloaded Maps with BaseCamp
I Am Still Not Seeing the Map Detail
If it is possible the issue is with a map you downloaded, or one preloaded in your device, see Related.
If you have tried the above and are still not seeing your map, there may be an issue with the map card:
- If you purchased the card from a retailer, it is recommended you exchange it with them
- If the card was purchased through Garmin.com, please contact Garmin Customer Support
