Installing the Garmin Drive App
The Garmin Drive App is a free smartphone application which allows you to connect a compatible automotive device and a compatible smartphone in order to add additional live features to your Garmin device through your phone's existing mobile data plan, such as weather, traffic and more.
To check device and smartphone compatibility see the FAQ  Garmin Drive App Compatibility and Availability
Contact your mobile service provider for more information about your service plan’s data and roaming rates.
To install and setup the Garmin Drive App on an Apple device:
Support: Drive App Setup on an Apple Device with a DriveSmart 55/65
  1. Touch the App Store icon on the phone
  2. Touch the App Store search bar at the top
  3. Type "Garmin Drive", then touch Search
  4. Find the Garmin Drive app  in the list of search results
  5. Touch GET
After the download completes, the app is ready to open and to be paired with your Garmin device. Instructions to pair the device with your smartphone can be found in the device's Owner's Manual.
To install and setup the Garmin Drive App on an Android device:
Support: Drive App Setup on an Android Device with a DriveSmart 55/65
  1. Touch the Play Store iconon the phone
  2. Touch Google Play search bar at the top
  4. Select the Garmin Drive app  from the list of search results
  5. Touch Install
If you encounter issues with the Garmin Drive App, view troubleshooting steps in  Troubleshooting a Bluetooth or Garmin Drive App Issue with a Garmin Automotive Device.
