Using a 64GB Card or Greater on a Garmin Dash Cam
All Garmin Dash Cams can use a 64 GB microSD card. Some Dash Cams can use a larger card. For more info on compatibility see SD Memory Card Sizes for Automotive Devices.
If using a 64GB or larger card in a compatible Garmin Dash Cam, the microSD will need to be formatted on the Dash Cam itself. Most Garmin Dash Cams will format the card automatically. To format the card manually see the owner's manual for the Garmin Dash Cam.
