Overview of the Garmin Explore Website
The Garmin Explore website is used for activating service on new inReach devices, maintaining your account, and viewing user map data. It now features the ability to sync data from other Garmin devices, like the Overlander, Tread, and zumo XT.
When visiting this page for the first time, you will need to select one of the options under the Create an Account heading depending on whether you are activating service for an inReach handheld device, or connecting another Garmin device. After selecting one of these options, the website will walk you through the initial setup process.
Once the Account Setup Process is Completed, you can do the Following for all Devices:
For inReach Devices only, These Services are also Available:
For more detailed information on these refer to the inReach Web Help manual. Additional information for completing other tasks through the Garmin Explore website can be found in the related content below.
Sujets connexes
