L'article présenté sur cette page n'est pas disponible dans la langue que vous avez sélectionnée. Vous pouvez en choisir une autre ci-dessous.
Remove Point of Interest (POI) from Future POI Searches on an Automotive Device
If you find a Point of Interest (POI) that is incorrect or that you simply do not want to display as a result in a POI search, you may remove the location from all future POI searches.
To remove a POI from future searches, follow the steps below:
  1. Touch Where to?
  2. Touch Points of Interest
  3. Locate the POI that you would like to remove
  4. Touch the "bubble" containing the name of the POI
  5. Touch Feedback or the menu button (three horizontal lines)
  6. Touch Report Error
  7. Touch Yes to confirm the removal of the selected POI from all future searches
The POI will no longer appear in POI searches on your device.
To report POI errors to Garmin that may be corrected in a future map release, see Reporting Map Errors on Automotive Devices
