inReach Mini 2 Messaging Functions
Steps for sending and checking for messages on the inReach Mini 2 are provided below.
Sending a Text Message
  1. From the home page, press OK to open the main menu.
  2. Select Send Message.
  3. Choose recipients from your contacts list, or select Type Contact to enter each recipient's contact information.
  4. Select Next.
  5. Select an option:
    • To start with a pre-written message, press Up Button or Down Button to scroll through the quick text messages.
      NOTE: You can add and edit quick text messages on the Garmin Explore website.
    • To write a custom text message, select Type Message.
      NOTE: To select from the autocomplete options, begin typing a word, hold OK, and use Up Button and Down Button to scroll through the options.
  6. When you have finished your message, select Checkmark.
  7. Press OK to send the message.
Sending a Preset Message
  2. Select Presets.
  3. Press Up Button or Down Button to scroll through the preset messages.
  4. Press OK to select a preset message.
    The content and recipients of the message appear.
  5. Press OK to send the message.
Checking for Messages
  1. From the home page, press Up Button or Down Button to scroll through the widget glances.
  2. Select Check for Messages.
