Searching for an Address by the ZIP Code on an Automotive Device
Starting with the City Navigator North America NT 2012.10 mapping version, most of Garmin's automotive devices will allow you to search for an address in the US1,2 using the ZIP code.
If your device has City Navigator North America NT 2012.10 maps or newer, the option to search by ZIP code will be displayed after touching Address in the Where To? menu.3
A Factory Reset is Necessary to Change the Device Locale for the Arctic Cat G8 Display, Camper 890, Camper 895, Camper 1090, and Camper 1095 Caravan and Motorhome Sat Navs, RV 890, RV 895, RV 1090, and RV 1095 RV Navigators, dēzl™ 780 LMT-S, dēzl™ LGV800, dēzl™ OTR800, dēzl™ LGV810, dēzl™ OTR810, dēzl™ LGV1000, dēzl™ OTR1000, dēzl™ LGV1010, and dēzl™ OTR1010 GPS Navigators, dēzlCam™ 785 LMT-S GPS Navigator with Camera, Kawasaki RIDGE 8" Tread Display, Tread® - Overland Edition, Tread® XL - Baja Chase Edition, Tread® XL - Baja Race Edition, Tread® XL - Overland Edition, and Tread® - SxS Edition GPS Navigators:
To Perform a Factory Data Reset:
- Open the device's Settings menu
- Touch Apps first then touch Tools on some devices
- Touch Personal
- Some devices skip this step
- Touch Device Reset
- Touch Factory data reset or Erase all data
- Touch Reset Device
- Touch Erase Everything or Reset Device
To Change the Device's Locale for all Other Models, Refer to the Device's Owner's Manual and Search for Restore Settings, Factory Reset, or Reset Default Settings.
1 Earlier mapping versions allow you to search by Postal Code within Canada, provided that you have set the device to search in Canada or one of its provinces. The listed devices above must be set as Searching Near a city in Canada to search by Postal Code. For further instructions, see Searching for an Address in a Different City or State on an Automotive Device.
2 To search for a ZIP or postal code, the device must be loaded with mapping that covers all or part of that specific ZIP/postal code.
3 On some devices, you may first need to enter the House Number, Country, and/or County/State you're searching in prior to having the option to search for a ZIP/postal code.
