L'article présenté sur cette page n'est pas disponible dans la langue que vous avez sélectionnée. Vous pouvez en choisir une autre ci-dessous.
Using the Older Update Method for GNS Database Updates
Updating the GNS™ avionics data cards using the Older Update Method:
Note: Using this method of database updates can only be done on a Windows computer.
- On fly.garmin.com, navigate to the GNS unit you wish to update.
- Below the button "LAUNCH GARMIN AVIATION DATABASE MANAGER," click on the link PC only update method.
- Ignore everything on this page except for the bottom right-hand corner, where you will see the databases.
- Choose the database corresponding to the card plugged into the computer, or go down the list of databases and change the cards appropriately.
- After selecting a database to download, you will be taken to a page with 3 bullet points. On the first bullet point, click the download link for your database.
- While downloading, notice the third bullet point, as well as the serial number and unlock code. These items will become important later on in the process.
- After the installer has finished downloading, double-click on the file to start the program.
- The program will launch, and the Older Update Method install wizard will be shown.
- Click the Next button, and you will be taken through a series of pages to verify that the card is correct, and to get the card's serial number.
- While clicking through, you will be prompted to verify the GNS data card. This will occur for both the IFRW and TAWS Datacards.
- Copy the serial number by clicking Copy button shown below.
- Paste the serial number that was copied in step 11 into the webpage under the 3rd bullet point into the box labeled "Serial:"
- Click on the button Get Unlock Code. Copy the unlock code generated by the program, then find the installer.
- The installer will look like the icon shown below and will be displayed on the taskbar. Most taskbars are located on the bottom of the computer screen.
- Once the Web Updater program is open again, click on the Next button until a page that asks for the unlock code is displayed.
- Copy the code into the box from Step 13, and then click on the Next button.
- A Finish button will be displayed. Click the Finish button, and allow the download to complete.
- Wait for the progress bar to fill and display 100% complete.
- Finally, eject the card and take it to the aircraft.
NOTE: If one of the following happens during the update process:
- A Runtime Error on the Older Update Method is displayed.
- The installer loops back to the "Finish" option.
- The installer crashes.
It is a strong indicator of a bad card. Contact your local Garmin Dealer to get a new GNS card.
