NOTES:
• Charts can only be shared with chartplotters registered to the same vessel account. See null for more information.
• If the chartplotter was previously registered to a different owner, or is registered to an account that does not belong to the owner, the registration of its built-in or supplemental charts cannot be transferred. The new owner of the chartplotter would need to purchase a new supplemental chart.
• See Marine handheld devices below if registering a GPSMAP handheld series device, such as a GPSMAP 78 or GPSMAP 86.
ECHOMAP and GPSMAP chartplotters can be registered in the Garmin Express desktop application. Certain chartplotters can also be registered in the ActiveCaptain smartphone app.
Any devices connected to the chartplotter using the NMEA 2000 and Garmin Marine Networks will be registered at the same time, as long as they are powered and turned on.
See null to check device compatibility with ActiveCaptain.
The following are required to register devices in ActiveCaptain:
A blank Class 10 micro/SD card (4 GB to 32 GB)
Do not use a card that has a preloaded chart installed.
A smart device (such as a smartphone or tablet) with Android or iOS
To Register Chartplotters in ActiveCaptain:
- Install the ActiveCaptain app
Download the app from the App Store or Google Play Store through garmin.com
Read and accept the End User License Agreement by checking the boxes, then select Continue
Sign in to or create a Garmin account, then select Next
Select Take the Tour for an overview of the app, or select Skip if preferred
- Create an ActiveCaptain card
Turn the chartplotter on
Insert the micro/SD card into the chartplotter
On chartplotters with multiple micro/SD card slots, any slot can be used
Select Set ActiveCaptain Card
If using a new card, select Skip. Otherwise, select Format
Selecting Format will erase all existing data on the card.
- The ActiveCaptain card will now be created. The micro/SD card must be left in the device while using ActiveCaptain.
- Connect ActiveCaptain to the chartplotter
From the home screen of the chartplotter, select A/V, Gauges, Controls
Select ActiveCaptain
Select Wi-Fi to enable the network
If necessary, follow the onscreen prompts to configure the Wi-Fi network.
Bring the smart device within 24 m (80 ft.) of the chartplotter
On the smart device, open ActiveCaptain
Select Connect to Garmin Wi-Fi
Select the chartplotter Wi-Fi network and enter the password
If necessary, select More to view all detected networks.
Select Connect
If prompted, select Connect again
If the message "A new ActiveCaptain user was detected. Is this user the owner of the vessel?" appears on the chartplotter, select Yes if the registered account belongs to the boat owner
Note: If the device has been previously registered to another account, or is registered to the incorrect account, the chart registrations cannot be transferred to the correct account.
- ActiveCaptain will connect with and register the chartplotter and all networked devices.
The following are required to register devices in Garmin Express:
Windows or macOS computer.
High-speed internet connection.
A prepared micro/SD card (4 GB to 32 GB).
NOTE: Do not use a micro/SD card that has a preloaded chart.
Check that networked devices (such as radar, sonar modules, SiriusXM and GPS antennae) are powered and connected to the chartplotter
Networked devices will be registered along with the chartplotter
Turn the chartplotter off
To locate the micro/SD card slot, check the device's Owner's Manual.
When the warning screen appears, select I Agree
At this point, the chartplotter will place a file on the micro/SD card that allows Garmin Express to recognize all marine devices connected to the NMEA 2000 and Garmin Marine Networks.
To Register Chartplotters and Networked Devices in Garmin Express:
Insert the prepared micro/SD card into the computer or an attached card reader
Launch Garmin Express
Go to garmin.com/express to install the latest version of Garmin Express.
Select Add a Device
Select Sign In next to the message Have marine devices or charts?
Create or sign in to a Garmin account using the email address intended for registration
If prompted, set up a Vessel
On the Set Up Your Vessel page, select Next.
Add the name of your vessel and select a country, then select Next.
After creating or selecting the vessel, select
Add
When the chartplotter is detected, select Add Vessel
Select View All Products Found to see all devices that will be registered.
