L'articolo visualizzato non è disponibile nella lingua selezionata. Puoi sceglierne un'altra tra quelle elencate di seguito.
Getting Started With Outdoor Maps Plus Subscription
With an Outdoor Maps+ subscription plan,1 you gain access to a wide variety of premium global mapping content. This content is regularly updated and the one subscription can be activated and downloaded directly to any of your registered compatible Garmin devices simultaneously via Wi-Fi, as well as the Garmin Explore app2 or Tread® app.
To access Outdoor Maps+ content, you must have a Garmin device that is compatible with Outdoor Maps+ or the Garmin Explore app:
Select your product series below for details on how to purchase, activate, download, and use the different types of mapping content that are available with Outdoor Maps+.
For more details, visit Outdoor Maps+ Subscription Plan.
1 Subscription begins when purchased and you will need to renew at the end of your plan, unless you have enabled automatic renewal.
A Garmin Explore app compatible device is required, but device map compatibility is not required.
Relazionato
