L'articolo visualizzato non è disponibile nella lingua selezionata. Puoi sceglierne un'altra tra quelle elencate di seguito.
Garmin Explore App Bluetooth Troubleshooting for the Foretrex 801/901
If you are experiencing issues with a Foretrex® 801 or Foretrex 901 Ballistic Edition outdoor navigator not pairing with your smartphone or tablet, this article reviews what to look for and troubleshooting for the Garmin Explore™ app.
If you are experiencing issues with the Garmin Connect™ app, see - Garmin Connect App Bluetooth Troubleshooting.
If your issues are concerning connection with the Garmin Explore app after pairing or syncing, see Related .
Items to Check
If issues occur when trying to pair for the first time, or after resetting your device, refer to the following suggestions.
Check for Software Updates
Garmin Device Updates
Use Garmin Express™ program on a computer to check for software updates available for the Foretrex navigator. For steps, see - Installing Software Updates to Outdoor Handhelds.
Garmin Explore App Updates
Access the app store on the phone or tablet to install any available updates for the Garmin Explore app.
App StoreGoogle Play
Phone or Tablet Updates
Most mobile devices install updates automatically, but it is best to confirm you have the latest operating system and install any missing updates. Consult your phone manufacturer for assistance, if needed.
Reboot the Foretrex and Phone or Tablet
Restarting the devices you are trying to pair will often resolve common Bluetooth issues.
Try powering off both the Foretrex and your phone or tablet, then powering them both back on.
Confirm Bluetooth® Pairing is Enabled
Check in the phone or tablet settings to ensure Bluetooth is turned on and not in Airplane mode. Contact the phone or tablet manufacturer for assistance, if needed.
To enable Bluetooth pairing on the Foretrex navigator:
  1. Press PAGE until you reach the menu page.
  2. Select PHONE.
    • NOTE: If you are not prompted to complete setup in the mobile app, select FORGET PHONE so that the Foretrex navigator can be paired.
Retry the Pairing if it Fails or Stalls
If you encounter a Pairing Failed error with the option to Retry, select Retry to try again.
If it fails again after selecting Retry, perform the following:
  1. Forget/remove/unpair the Foretrex navigator from the Bluetooth menu in the phone or tablet's settings.
  2. Forget the smartphone in the Foretrex device settings:
    2. Select PHONE.
    3. Select FORGET PHONE.
  3. Start the pairing process again in the Garmin Explore app.
Allow Enough Time for the Phone or Tablet to Find the Foretrex
During the pairing process it can take 20+ seconds for the phone or tablet to find the Foretrex navigator.
If your phone or tablet does not find the device right away, allow more time. Once the device has been found, select Connect it.
Ready to Connect Foretrex 801
A six digit pin will appear on the device after you select Connect it.
Connect the Phone or Tablet to Mobile Data and Try Again
If the Foretrex navigator is not pairing with the phone or tablet connected to Wi-Fi, try switching to a mobile data connection and try again.
Relazionato
