L'articolo visualizzato non è disponibile nella lingua selezionata. Puoi sceglierne un'altra tra quelle elencate di seguito.
Topo 24K Map Segments
Garmin's Topo 24K mapping products are made up of sections called map segments. Our Outdoor devices can only hold a certain number of mapping segments, which can cause issues if installing multiple regions of the Topo 24K maps, or installing them alongside other mapping products.
The following shows a map of the regions and the number of map segments found in each.
Topo US 24k Version Three Regions
RegionSizeSegments
West3.72GB1822
Southwest2.85GB1812
North Central2.10GB and 2.50GB1665
South Central2.92GB1008
Northeast3.22GB1059
Southeast3.78GB1188
Alaska Enhanced11.60GB157
Finding the Map Segment Limitation for an Outdoor Handheld
Utilizing the appropriate number of map segments for your device can help ensure your map functions correctly. For more information about map segments and the number that can be stored on an outdoor handheld, select the appropriate link for your device below.
Outdoor Handhelds
Alpha® Series
Dakota™ Series
  • Dakota Series
    NOTE: The Dakota 10 handheld is not compatible with the currently available 24K mapping. It is only compatible with 24K mapping from a CD/DVD.
eTrex® Series
GPSMAP® Series
Montana® Series
Monterra™
Oregon® Series
Rino® Series
Legacy Handhelds
1 Select areas of the Topo Alaska Enhanced map are in 24K coverage while other areas are 63K.
Relazionato
