제품에 대한 자세한 정보를 확인할 수 있습니다
지금 보고 계시는 글은 현재 선택된 언어를 지원하고 있지 않습니다. 아래 드롭다운 메뉴에서 다른 언어로 변경할 수 있습니다.
"There is a problem with the Microsoft .NET installation" Error in BaseCamp
A corrupt user configuration file can cause Garmin BaseCamp™ software to fail to launch and display the error. There is a problem with the Microsoft .NET installation. Please uninstall and reinstall all versions of the Microsoft .NET Framework.
Delete the Contents of the GARMIN_Corp User Configuration Folder:
Windows Vista and Newer:
  1. Hold the Windows Key (Image of Windows Key ) and press R
  2. Enter %userprofile% in the Open field and click Ok
  3. In the folder that opens up, AppData is a hidden folder. If you don't see the AppData folder, click View at the top, then click the box next to Hidden Items to put a check in it.
  4. Open the AppData folder
  5. Open the Local folder
  6. Open the GARMIN_Corp folder
  7. Delete all files in the GARMIN_Corp folder
Windows XP:
  1. Hold the Windows Key (Image of Windows Keyboard2) and press R
  3. Open the Local Settings folder
  4. Open the Application Data folder
  5. Open the GARMIN_Corp folder
  6. Delete all files in the GARMIN_Corp folder
Once this folder is emptied, Garmin BaseCamp software should launch normally. If the issue persists, see Related Content.
NOTE: Deleting this file will reset Garmin BaseCamp software's preferences to default. All other user data (waypoints, tracks, routes, maps, etc.) will be preserved.
참고
