Playing AirPlay or UPnP on a Fusion® Apollo™ Stereo
A Fusion® Apollo™ stereo can connect to Wi-Fi using Ethernet, or on some stereos via a built-in Wi-Fi router. When connected via Wi-Fi, an Apollo stereo can stream audio from a smart device using Apple AirPlay or UPnP (or Universal Plug and Play).
Streaming from Apple AirPlay
  1. Follow the steps in Networking Fusion Apollo Stereos to connect the stereo to a Wi-Fi network
  2. Connect the Apple device to the same Wi-Fi network as the stereo
  3. Open the app audio is to be played from on the Apple device
  4. In the app, select airplay icon 1airplay icon 2 AirPlay and select the stereo from the device list
  5. Begin playing audio from the app
  6. The stereo will automatically switch to the AirPlay source
Notes:
    • Some Apple devices can be connected to a network using Ethernet rather than Wi-Fi
    • The AirPlay source is not shared to other grouped stereos on the network
    • AirPlay 2 can connect to and play over multiple stereos on the same network, however the stereos cannot be grouped
    • Some AirPlay devices will adjust volume on the stereo when the Apple device volume itself is adjusted. This is built into the Apple device and cannot be disabled
A password can be set for AirPlay connection on each stereo.
  1. Select fusion menu Menu
  2. Select Settings
  3. Select Source
  4. Select AirPlay
  5. Select AirPlay PASSWORD
  6. Enter a password and select confirm password
Streaming from a UPnP device
  1. Follow the steps in Networking Fusion Apollo Stereos to connect the stereo to a network
  2. Connect the UPnP device to the same network as the stereo
  3. On the stereo, select fusion sources Sources
  4. Select UPnP
