"Error on reflashing" when Trying to Update the Chrysler Uconnect Navigation System
Follow the steps below to let the vehicle do a full power cycle/sleep cycle if you receive the message "Error on reflashing" when trying to update the software or maps on your Chrysler, Dodge, Jeep, or RAM Uconnect system:
  1. Make sure all the vehicle lights are off
    • If your vehicle has a push button or keyless start, make sure the FOB is out of range of the vehicle.
  2. Shut down the vehicle
  3. Open and shut the vehicle door
    • If your vehicle has a keyless ignition system, you will need to exit the proximity of the vehicle.
  4. Wait for at least 5 minutes
  5. Start the vehicle
  6. Try updating the map again
The update should continue.
Contact your dealer if this does not correct the issue.
