ShotView™ App
The ShotView app allows you to easily view, edit, and save your sessions. To pair your Xero® C1 Pro Chronograph to the ShotView app follow these steps:
- Download and install the ShotView app for your smartphone using one of the following:
- When presented with the QR code you can use that to select the app
- If you chose to SKIP the first time through setting up your chronograph:
- Select SETTINGS > CONNECTIVITY
- You must have the STATUS set to WAITING ON PHONE or CONNECTED after which you can select PAIR PHONE
- If necessary, setup an account and log-in to your app
- From your ShotView app, select Add A Device
- From the ShotView app you can also select the icon in the upper right corner and select Add A Device
- Follow the prompts and, if not already enabled and prompted, select Allow to let your smartphone communicate with the chronograph
- Select Connect it and respond to the pairing prompts as necessary
- Select Done, your Xero C1 Pro chronograph and ShotView app are now connected
